sunrisefordparts
Hi,
Can I get the last 8 digits of your VIN please?
thanks,
Sean
trim panel: List $142.48 -- your cost $95.75
120V outlet: (can't get cover separate) List $11.10 -- your cost $7.66
+ shipping
**figure 5-7 days lead time on the panel... it is coming straight from the supplier.
thanks,
Sean
Q608501
fords4life
Greeley, CO
+ shipping
thanks,
Sean
Q608501
Sean - Thanks! I'll take both, but any chance of getting a picture of the part for the trim panel, I just wanted to double check the switch layout when I get home.
Thanks,
Nathan
sunrisefordparts
Thanks,
Nathan
pics are attached, when you get a chance PM me your email address again and I will email you the quote.
thanks,
Sean
ernestbeckner
ok guys I'm bullet prodding my 6.0 and I just got the heads back from the shop all new spring valve seats valve guides bronze but they drop the ball they couldn't do the fire ring .im planing on 30 over injector and the wicked wheel and I have the edge attire tunner . my question is should I go ahead with the fire ring
Sent from my LM-G820 using Tapatalk
sunrisefordparts
Sorry, I haven't had any experience with fire rings, you may want to start a new thread and see if anybody on here may have been down that road....
thanks,
Sean
j.mo
I ordered a bed bolt a few weeks back. I need to go ahead and order 2 more for an 06 f350 short bed. They are the very 2 front bolts nearest the cab. The one I ordered doesnt seem to be long enough. Are there different lengths?
Thanks guys
Hi,
can I get the last 8 digits of your vin just to make certain. Also do you have the part number that we sent handy?
thanks,
Sean
Ok. Dropped the ball on this.
I'm not sure of the part #, I had just asked to order a bed bolt not knowing there would be a difference.
Last 8 of the vin - 6EA04671
sunrisefordparts
Looks like there are three different numbers depending on location... see attachment.
thanks,
Sean
fords4life
Greeley, CO
Sean - Can i get a price and part number for the 3 larger relays in the power distribution box for a 99 7.3? Should be PCM, IDM, and Blower Motor relays. Engineering number is F0AB-14B192-AA.
Thanks,
Nathan
sunrisefordparts
Thanks,
Nathan
Hi Nathan,
the latest number for those is:
5M5Z-14N089-A list $4.82 -- your cost $3.32 each + shipping
thanks,
Sean
sunrisefordparts
Are any of these available?
E5TZ-9J306-BA
Hi,
unfortunately they are currently on backorder with no ETA.... There are a few dealers showing to have stock on the locator, so I might be able to scrape one up for you, but the cost would depend on what the selling dealer would charge me...
thanks,
Sean
weareweird69
Blairsville, PA
Hi,
thanks,
Sean
Let me know what you can get one for if you can... Two if possible.
And...
Hopefully these aren't discontinued or back ordered lol
F4TZ-9C330-B
F5TZ-9A318-C
Should be feed and return hard lines for on the 7.3 OBS PSD.
Roccafellas
Looking for two pump to head lines
8c3z-9a332-b and 8c3z-9a332-a
Thank you.
sunrisefordparts
And...
F4TZ-9C330-B
F5TZ-9A318-C
F4TZ-9C330-B replaced by F5TZ-9C330-C: List $36.67 - your cost $25.30
F5TZ-9A318-C: List $24.03 -- your cost $16.58
I do have both of these in stock....
there are quite a few dealer showing stock on the 9j306, figure around $85
+shipping
thanks,
Sean
Q613803
