Tuning.
Powerstroke Cowboy
Montana
Thanks man. You happen to know where to find it? I google and a ton of random stuff pops up.
No problem. I will just put the part number on for you. That way you can find the best price. I will say this, most place's are out of stock. They can back order them though.
Before spending the money I would try to verify it's the VGT controller that's bad.
Here is the part number 59001107387.
Jbonfiglio
Oregon
Thanks a ton man!
TD-5
British Columbia Canada
Before replacing the VGT actuator, check that the MAP sensor & the exhaust pressure sensor (back pressure) are reading correctly. Ensure the MAP sensor & port in the Manifold are not plugged up. Same for the tube & fitting that connect to the EP sensor to the exhaust manifold.
Jbonfiglio
Oregon
I have replaced the EP sensor and tube with brand new ones, cleaned MAP and port and cleaned MAF last night.
