7.3 Exhaust options
Cdaley403
Washington State
I’m hoping to do a 4” exhaust and seeing a lot of straight pipe options but am looking for an option that deleted the cats but still has a muffler. What are y’all running. The only thing from MBRP I’m seeing is either a straight pipe or a cat included system.
Thanks!
TD-5
British Columbia Canada
I put a Flow Pro 4" turbo back Stainless system on my old 97 crew cab a couple years ago after the MBRP aluminized system rotted out. The down pipe was a little tight and took a little fiddling to get it in the right spot so it didn't rattle, but so far so good.
psduser1
on the road
99 should be able to use the sd exhaust, with a 4" dp.
6.7powersmoke
Ga
Just delete cat with piece of 3.5" pipe, put in a 3" down pipe. The stock muffler is straight through. I guess you cant buy the "cat test pipes" anymore?
