Extended cranking, fuel system tests.
Tiha
Super Moderator
Super Mod
You are going through it with this truck!
I got a similar situation. I just replaced all 8 injectors cause had one nearing the 2.0 mg mark and a little shaky at 65-68 mph. But it was an episode, I decided to do the work myself after spending $5600 getting a delete and upper oil pan re-seal.
Had the fuel knock after that work was completed, fixed with resetting the fuel trims and crankshaft position sensor…actually I reset everything available in forscan on the PCM side lol.
Well, the very first injector I started (#1 cylinder), the hold down bolt snapped. But I wasn’t gonna let that stop me so kept moving through the rest. Like you all the injectors came out pretty easy, but I had a valve cover job to do cause of that bolt.
So I pulled the valve cover, trued welding a nut to the bolt several times but couldn’t get it out. Hired someone to drill it out but he couldn’t so he ended up throwing a helicoil in there. I was sketchy about it but said screw it, put everything back together.
BTW…I used electrical shrink wrap to cover fuel injector fittings and fuel supply rail fittings, melted one side together and basically made a “cap” out of it to keep dirt out. New injectors came with all the fancy caps.
Back to the helicoil…didn’t work. Couldn’t get it to 22 ft-lbs + 90 degrees but got it to hold as tight ass I could. Had to go back to work and this is my only vehicle. I through my ratchet and star bit in the truck just in case, and glad I did. Anything over 1800 rpm knocked the #1 injector out. It was actually plopping in the injector cup well. So for the entire week, I was driving like a 90 year that loss feeling in their right foot. It popped a few times, I would know by the “cylinder 1 contribution code”, I would pull over and re-tighten.
Well, finally got back to work on it today. Really didn’t want to but knew I had to. Had to fix that helicoil. In the meantime, I ordered a new valve cover, new gasket, 4 new hold down bolts. Got the valve cover off in about 6 hours (luckily it’s the passenger side).
I am glad I didn’t wait too long, the crush washer on that injector was warped, there was carbon build up in all the indents and all over the o-ring of the fuel injector. The fuel injector grommet was shredded on the underside which left rubber shrapnel in my valve components. The fuel injector cup well looked like murder. Scrubbed that. Taped a 1/2 inch heater hose to a shop vac and swept out that hole as good as I could. Cleaned up all the rubber with q-tips and the vacuum as well. That what took me the longest.
I threaded the hole to 10mm x 1.5 and threw in a threaded insert 8mm x 1.25 (hold down bolt size) with red lock-tite. Should have just done it my self in the first place smh. Worked like a charm, was able to get the correct torque.
After I got everything back together, 13 hours of straight work, 6 white monsters, I primed the truck 8 times and I got the same code…P2291 and the truck wouldn’t start. Tried 3 more times and finally got it to start. I was certain there was air in there so I would turn on the key and hurry to the primary filter to loosen the thumb screw to release fuel until it was running fluently with no air. It still takes a few cranks to start. I started it 3 times and every-time it seemed to start on the last crank in the series lol but the code didn’t re-populate. Fuel rail pressure reads approximately 4000 psi at idle and increases with throttle. I think I just need to get it on the road and get that fuel pressure higher. If that doesn’t work I’ll be pulling the primary fuel filter and changing that first.
2015 F350 XLT 6.7 Diesel (198k miles)
Upgrades:
- Gen 2.1 CP4 Disaster Kit
- S&B Air Filter
- Secondary Coolant Filter
Recent Work:
- Upper Oil Pan Re-seal ($3200)
- Delete ($2400)…should’ve done myself
- Motorcraft Fuel Injectors, kit with Supply Tubes and hold down bolts ($5800 - $1400 core charge = $3400)
- New Valve cover ($142)
- 2 Valve cover gaskets lol ($60)
- Drainable Front and Rear Differential Covers with removable gaskets ($300-ish)
- New Lower Oil Pan ($40)
- New Transmission Pan ($70)
That was one of my worries was a hold down bolt. At the end of the day I am not sure if I was lucky having to do the CP4 twice or if I would have rather dealt with Broken bolts. LOL
Anyway, awesome you got it going. Helicoils can work, threaded inserts are better. On longer holes like that I will use more than one helicoil. Drill and tap all the way to the bottom and get as much in there as you can.
Glad you got it working.
Tyb_6.7
It was a pain, but glad I decided to pull the valve cover again. Definitely going to stick with threaded inserts from here on out lol. Took it out for a spin yesterday and everything checked out. Starts on the first couple of cranks so it was just air in the system, although I do have a small fuel leak coming from the thumbscrew on the primary filter housing, it’s a damn Dorman replacement cause I broke the last one, probably just needs a new o-ring.
You may be sucking air through that fuel return line that keeps popping off, I had to replace mine when I did the fuel injectors cause of course…I broke one when pulling it off. Not sure if you fixed that issue yet. I read through this whole forum just forget where you were on fixing that.
Tiha
Super Moderator
Super Mod
I think my issue with it popping off was to do with the cheap return line I got. Had to try 2 or 3 times to get it to seat properly. I did finally get it to seal up.
Tyb_6.7
I did the same thing, bought a cheap one off Amazon for like $33, that one ended up springing a leak so I had to get a ride to Autozone and picked up a Dorman one for $150 at Autozone and replace it in a Walmart parking lot. Mine was spewing out fuel while running. There was actually a slit in the line.
