so i have the fog relay kit ordered. now i have been thinking of how to keep the fogs on with the hi's without getting into it rewiring stuff. i am also running retros hids. now if i tap into the HI beam power wire from the oem plug and run a wire to the power wire on the relay side (on fog kit) would this work without damaging anything? if this were to work, would there be a second the fogs would flash off/on between the lo/hi (vice versa) transtition? goal is to to keep using stock headlamp/fog switch for its purpose without fogs turning off when swtiched to hi. 08-up SD arent quite as easy as previous years to get hi/fogs to work together.
thanks
thanks
