Ford Dana 80 Dually rear questions
NRHX2009
Elizabethville, PA
I have a Ford Dana 80 rear from an 03 F-350 under my F-250 and i am running single wheels on it. The tires hang way out from the dually wheel adapters. Is there a way to change the hub assembly to a single wheel hub.
As far as i know, Ford Never used a Dana 80 single wheel application like the Dodges do.
Any info would be great. Thanks
TrailerHauler
Michigan
You'll have to live with it from what I can remember, get a set of spacers for the front, or change your wheel offset.
I don't believe you can change the hubs to any different configuration on a DRW Dana 80.
fifty
I am running a 2002 D80 rear and a 2008 D60. They almost match up. The D80 is still about 1/2 inch wider on each side. Run with 05+ offset rims and you cant tell a difference.
CRANEMAN
What u needed was a D80 out of a f350 cab and chassis. They are shorter and tuck rite under there nicely.
Cat_rebel
Rebecca Black took my seat
Thats what i figured... Only real option would be to get a dodge d80 srw axle
Then you'll have to reweld the spring perches & your rear will be 8x6.5 & the front will be 8x170mm.
:whs: Just reweld the spring perches on a C&C axle & rock out, HRT did that on his old red truck AFAIK.
Hotrodtractor
Mingo, Ohio
Yep - cab and chassis axle to use under a SRW truck and keep the rear track width as narrow as possible without a ton of work.
rat49f6
Vernon,NJ
Are u looking for a drw cab & chassis axle from a obs?
Sent from my T-Mobile G2 using Tapatalk 2
Hotrodtractor
Mingo, Ohio
no, 99-03 F-450/550 Superduty with 8x170 bolt pattern.
Actually you want an F350 cab and chassis axle - all the F550 axles were bigger than Dana 80s and I am not sure on the F450 axles - but I think they were all Dana 80s - you should check on those.
IDP
The 450s were all 80's the 550's were the big rears. I believe River City Diesel would machine the hubs so the wheels lined up and you used the stock axles.
NRHX2009
Elizabethville, PA
no idea. All the 350 SRW trucks ive seen have sterling axles like the 250's. But not sure for the 350 cab and chassis. 4" axle tube diameter?
