1" spacers
Vodomagoo
Myrtle beach
my 07 Is rubbing pretty bad when I turn to park, I'm on king ranch 20's with nitto's and was thing a one inch spacer might do the trick. Who has some good ones? Was hoping I don't have to get ones that bolt on.
dzldoctor
I bought some nitto 20's mine rub the leafs on tight turns. I was thinking th same thing.
Zmann
you guys have two different suspension coil vs leaf front
op just get a coil spacer for the top of yours ,, it replaces the oem ,, not a bad job to drop in
MINK
London,OH
Unless he is rubbing the radius arm.
Zmann
IDK He is asking for a spacer that doesn't bolt on I was assuming coil spacer but I guess you might be correct and He might be thinking wheel spacer ?
here is a daystar coil spacer with a shock extender
Zmann
Ahh
I don't like the spacers so much 1/4 inch is all I would ever run
you really just need rims that have the proper offset IMHO
MINK
London,OH
Yeah I am rubbing the radius arm and sway bar, truck has a 6in lift already
1" wont jive - you could go with 1.5" bolt on spacer but then you have to cut the wheel studs. Been there done that...
Save for a set of wheels with some negative offset and be done.
Vodomagoo
Myrtle beach
I kinda figured 1" wouldent fix it all the way but it would make it a whole lot better I'm thinking. Right now I like the kr wheels to much to dump them
Zmann
I don't think they sell 1 inch because the stud wouldn't be long enough to have a pass through spacer and it wouldn't be thick enough to machine the pockets for a bolt on style
if you did find or make or stack to get a one inch pass through you would need longer studs IMHO
