Anybody have a how to guide on polishing turbos?
Matt
Minnesota
Send them to these guys mirrorfinishpolishing.com. I have heard its a lot of work to get a good finish, but I've always wanted to try.
Powerstroked162
On Da Juice
Wa. State
I'd contact Mike at No Limit and see if he'd under take it. His polish job on the intake piping is mirror finish quality
O2ShootTheJ
The issue is im a college student on a VERY tight budget as half of my summer was dedicated to dental school applications and the DAT and not working.
Would like to save money and do it myself if possible. Otherwise they'll probably just stay how they are now although i'll look into that place Matt
Sent from my DROID BIONIC using Tapatalk 2
Matt_P
Lima, OH
Mine isnt a mirror finish, and unfortunately its not looking as good because my dumbass forgot to clear coat it but I polished the cover on my 66, Jason polished my valve cover and cleared it and it still shines real nice.
My turbo was so dirty I started with a fine wizzer wheel on an air tool then went to 320 grit, then 800 grit then 2000 and then buffed it with polishing compound on a bench grinder, this was the outcome:
Like I said not the best by any means but it got me by on the cheap
O2ShootTheJ
looks good! Does it have to be a special kind of clear? I feel like it would melt off the turbos
O2ShootTheJ
ok cool thanks! and is removing/reinstalling the housing pretty simple? I've never done it before
Matt_P
Lima, OH
No problem, yeah its simple, they are normally held on by either a v band clamp or bolts which was what held mine on, youll just have to clock the housing when you put it back on, I would make a mark so you know where it was and be sure not to accidentally hit the compressor wheel with the housing when reinstalling
O2ShootTheJ
awesome thanks! Clocking is just making sure the outlet is in the right direction, correct?
My only real worry is getting it back on without hitting the wheel I think.
ColtonP
Tyler, Tx
Anybody figure out a good way to get in the corners? There has to be a better way than just sandpaper and finger.
ColtonP
Tyler, Tx
I finally found a rock small enough to get most of it. Still have some I can't get to though.
