Microns, whats smaller?
Big Bore
9000ft in the CO Rockies
Ok I'm going to post this down here and hope no one upstairs sees it. LOL
Buying replacement filters for my AD and they sell 2 and 10 micron filters. Since it's pre-pump, and I am deleting the stock filter housing and doing a remote post pump spin on, I don't see the need for a super fine pre-pump filter.
Problem is, for some reason I cant determine which is smaller, higher numerically or lower on the microns. I'm thinking lower numerically but want to be sure so I can place an order.
Thanks guys.
2 micron is smaller... way smaller 10 od usually primary 2 is secondary for fuel
sgleshot
I run a 10 micron absolute post pump currently in my regulated return setup, its better than stock, but id like to go a little finer with it. Im running a 12 micron nominal water seperator for the pre-pump filter. Had the same setup on 2 different superduty's, works great.
rsr911
Akron, Ohio
For reference 25.4 microns equals 0.001"
More reference? Typical main bearing tolerance in an engine 0.001-0.003" with the loose side being favored in a drag race application. Your oil filter is about 25 microns.
On my IDI I have to filter to 5 micron absolute or better to prevent onboard filter clogging. I have seen evidence to suggest that the PSD onboard filters are more coarse than the IDI filters.
A human hair is approximately 25-50 microns in diameter.
Thickness of the ink printing on most flexographically printed labels, less than 2.5 microns or less than 0.0001"
One layer of evenly applied paint is 0.001-0.002" thick.
389sixpack
New Jersey
That is not correct.
1 micron = 10^-6 m = 0.000001 m
10 micron = 10*10^-6 m = 0.00001 m
1 µm = 3.937007e-05 = 0.00003937" or approx 4 hundred thousandths of an inch.
and a 10 µm will pass particles smaller than 0.0004" 4 ten thousandths of and inch.
rsr911
Akron, Ohio
My source among others is www.onlineconversion.com. I have seen what appears to be a metric micron definition such as u mention as well as my definition. My definition is a micron is essentially one thousandth of a millimeter. Btw if u multiply .00004 x 25.4 you get about 0.001" which is what I said. If u do .00003937 x 25.4 you get exactly 0.001". So what was I wrong about.
Mdub707
Mohawk NY
More importantly, you need to be looking at these filters if they are nominal or absolute.
rsr911
Akron, Ohio
I recirculate through 1 micron nominal filters and pump into storage and the truck through 3-5 micron absolute depending on what brand I'm using.
BnjmnAlan
California
What kind of 1 micron nominal filters are you using? Are they the string wound ones from Mcmaster?
rsr911
Akron, Ohio
IIRC it's BF7587 and fits FB1811. I know I got the filter number right, not certain about the filter head.
