Front end issues?
SouthFlstrokin'
My front end is having issues. Let me explain.
1. At very low speeds there is a loud metal to metal squeal it sounds like.
2. When braking there is a serious shake to the truck.
3. When taking a left hand curve my passesngrr side tire seems to make some humming noises.
4 the passenger side tire is having west on the middle to outside.
The tires are brand new, just balenced by my buddy at an Audi dealership. They are 31x10.5s on the factory 15x7 wheel.
The truck is a 95 f 150 4x4 4.9 5 speed stock ttb
Anyone think they can help me?
kadeninabnitt
Martinsville, IN
for the shaking id say warped rotors and the squeel check your dust sheilds for the brakes mine did that and my sheild was mangled and rubbing the wheel and rotor
kadeninabnitt
Martinsville, IN
yeah there pretty easy remove brakes remove lockout cap there is a couple snap rings to remove then the lockout should come out then you have youre hub nut you can remove it without the socket but its easyer with it its around 18 bucks at the parts store get the nut off and you can remove the hub replace bearings reverse process
Or it could be worn front end and bad wheel bearings.
I bought a superlift superrunner kit for my 96 that replaced all the ttb junk and it helped but.that alone cost 1k bucks.
You'll be working on this all the time, just so you know.
SouthFlstrokin'
Or I could just not work on it at all... Lol still goes from point a to b.
Thanks though
