sunrisefordparts
I got a photo of the VIN for that headlight switch for a 2005 Sable with foglights and without auto lamps if by some strange change that helps with an alternate part number that is not discontinued
Could you also start me a qoute for a 2006 Taurus w/o flex fuel for a gas cap and a oil drain plug and the gasket if they are separate from each other. I need to get that ordered this week.
on the taurus is it a single or dual cam 3.0? and on the sable the only switch offered with fog lamps would be the auto headlamp switch.
Tom S
That is so wierd in I even have the pigtail from that same car and it does not even have the trigger wire for the auto headlamps.
Single cam on the 2006 Taurus aka a Vulcan not a Duratech 3.0. The VIN is 1F1AFP53UX6A236181. No flex fuel just in case that was relative on the fuel cap.
Fuel Cap
Oil Drain Plug plus gasket / 0-ring if it not included with the drain plug.
sunrisefordparts
Fuel Cap
fuel cap list $25.60 sell $16.64
drain plug w/seal list $9.82 sell $7.36
q#282416
7.3 Whitey
Wichita KS
whats the price for a new thermostat on a 2002 ford 7.3? No waterpump, but I want new bolts for it also. With shipping to 89508
sunrisefordparts
tstat list $33.36 sell $30.36
long bolt list $3.45 each sell $2.59 each x3
medium bolt list $1.52 each sell $1.14 each x4
short bolt list $7.40 each sell $5.55 each x2
q#282460
7.3 Whitey
Wichita KS
q#282460
All I need for this is:
8592 Outlet, Water Pump
8255 Gasket, Water outlet
8575 Water Thermostat
The outlet, the thermostat, the gasket/o-ring, and the three outlet bolts (no part # in the manual). The leak isn't coming from the housing anywhere; just the bottom of the outlet (Cleaned and inspected for leaks with system pressurized)
And does the Tstat come with (8255) o-ring?
sunrisefordparts
tstat list $33.36 sell $25.69 w/ seal
tstat housing list $32.15 sell $24.11
3 bolts list $4.66 each sell $3.49 each
q#282498
