Blacksmokin22
Price on high pressure oil pump, both left and right oil lines from pump to heads, icp, icp connector, ipr, hpop gasket, fuel filter cap, and water drain on back of fuel housing. For a 2001 7.3l f450
sunrisefordparts
hpop list $771.56 sell $636.54 w/exchange
lh tube list $140.42 sell $105.31
rh tube list $157.33 sell $118.00
icp list $192.60 sell $144.45
connector list $84.58 sell $63.43
ipr list $268.98 sell $201.73
hpop gasket list $37.67 sell $28.25
drain valve list $60.47 sell $45.35
rh tube from hpop would need to know if it has 90 on both ends or just one.
q#283351
free shipping w/return label for core.
blk99
HD torque converter price please.... 4R100...6 stud
Those are triple disk, right?
topgun
What's your price on a complete head gasket kit for a 2004 6.0 for both sides?
topgun
is that the complete kit with all the little o-rings and valve cover gaskets included?
sunrisefordparts
no those kits are just head gaskets, bolts, and stand pipes. sounds like your looking for a valve grind kit list $623.06 sell $467.29 that should have from head gaskets up.
jdsf350
southwest wi
quate on 2008 f350 4x4 front and rear shocks, both upper and lower ball joints, and passanger side tie rod end. thanks!
sunrisefordparts
if possible could you get me last 8 of your vin, it would narrow down the 10 different options for shocks. thanks
sunrisefordparts
front shocks list $55.83 each sell $41.87 each
rear shocks list $54.63 each sell $40.97 each
upper b/j list $67.47 each sell $50.60
lower b/j list $88.00 each sell $66.00 each
tie rod end list $170.13 sell $127.60
locking hubs list $202.63 each sell $151.97 each
q#283671
