LED light bar mounting bracket.
Slate
Lafayette, IN
I've heard of Whelen (brand). But I thought they only made Emergency light bars. I just googled it, but I couldn't find a light bar mount.
Snake
Flo Rida
Give Bulletproof Diesel a call. Last I heard they were working on brackets. This is the prototype.
Lowdown89
Travelers Rest , SC
I'm pretty sure Trevor at PMF said e was thinking about building some mounts, I'm ure if bulletproof makes some they will be nice as well.... I bought a mesh grill for my truck and I'm mounting my 24" bar behind it
HeavyAssault
Middle, VA
KC Hilites have some replacement fog light brackets that fit the OEM mounting points. If you get those and then the Rigid bracket it's a clean install.
Coxey Diesel
Athens Alabama
Well, I got the bar in and I'm not seeing how its possible to mount. Any 05-07 guys with a light bar that could chime in would be great.
HeavyAssault
Middle, VA
Since Rigid has a wide U shaped bracket that would be what you need to buy. This bracket has a long bar that goes across the back of the light housing. There are several mount holes along this bracket. Get the KC brackets and mount it up.
Coxey Diesel
Athens Alabama
I've got a GG light bar so it's a different mount. I'm also trying to mount it IN the bumper hole.
HeavyAssault
Middle, VA
They bolt in the OEM fog lights mount holes. There are two upper holes and one lower mount hole. The OEM bumpers all have the holes that will allow these brackets to fit.
