Never Balance tires again
7.3 Whitey
Wichita KS
Looks pretty cool but cost wise I rotate my tires for free every oil change. Only had to buy a few weights once. When I flat spotted. I get how awesome it is but adding 60$ to each set of tires??? I'm not sure. And it can still get in the valve core if you have the valve stem at the bottom. Whats the difference between that and when you put them in the first time and putting them next to your valve? Other than spraying out of the bead?
Spoolin'
Florida
I never said put it in the valve cores, but if it is in the tires and you check the air it will get into the core. Now maybe it is finer than the beads and won't get stuck in the core and if that is the case then it would be better.
My bad lol I read your post wrong. Iv never used anything else so I cant compare the materials used.
Spoolin'
Florida
You can take this out of your old set of tires and use it again in a new set. I havnt reached that point yet I only have 20,000 miles so far on my 35s. You don't HAVE to have it and can stick with weights it just makes for a nicer ride and longer tire life vs weights.
JMart
DFW
Are you trying to sell this stuff or are you just recommending it? To me this looks like a sell thread. Are you selling just an extra set or are you selling a lot of this stuff to make money?
Are you the same guy that was selling this stuff on Face book in the Powerstroke page?
Spoolin'
Florida
Both. I recommend getting it and buying which ever you prefer. I also have the stuff I use if anybody would like to try that. And yes that was me. Just showing some alternatives to weights and seeing if anybody has any input. It has worked great for me.
