94.5 7.3L Turbo up pipes
Redman920-06 350
Wisconsin
HELP! I'm Sorry if this is a duplicate post but For the life of me I cant find a topic. I'm Looking for a turbo up-pipe replacement on a obs 7.3. The '94.5 model. Any help would be GREATLY appreciated.
THANKS!!
Redman
CSIPSD
Bend, OR
Remove turbo.
Remove up pipes.
Install new up pipes and new doughnuts.
Reinstall turbo.
Enjoy.
Redman920-06 350
Wisconsin
Unfortunately its not doughnuts :( The pipes are actually rotted away, DAMN that Sodium-chloride crap they put on the roads!:badidea:
BTW Im looking for a stock replacement.:biggun:
Parker, TX
Here are some part numbers for the up-pipes:
Turbo Exhaust Up-Pipes
(Ford) F4TZ-6K854-A (Driver’s side)
(Ford) F6TZ-6K854-A (Passenger side)
(International, bellowed up-pipe kit for 94-97) 1843486C92 ... about $800!!!
Turbo Exhaust Collector Donut (at top of each manifold-to-turbo up-pipe)
(Ford) F4TZ-6K854-C
Turbo Up-Pipe Bolts
(International) 1821640C1 (long for manifold end, 4 required), part number was superseded by part number W300013
(International) 1822895C1 (short for turbo collector end, 4 required), try 1844044C1 which will cross to W301160 which was superseded by W301640
(Ford) 40066R1 (Nuts, 4 required), superseded by W300051
Hope that helps. Cheers!
Magnum PD
VA
I think I may have cut off about a 1/4' on one of them. May be better to get new.
Redman920-06 350
Wisconsin
(Ford) F4TZ-6K854-C
Turbo Up-Pipe Bolts
Actually it dose! The local ford dealer can get them tomorrow. IF their wrong Ill be hitting up Magnum PD hes got em used XD Cant see his name on this stupid screen.
THANKS GUYS!!
:ford::fordoval:
Redman920-06 350
Wisconsin
Ok guys, so...Their was miss communication on my end, the Pipe actually needed is the Y-Pipe piece. its cast so im sure itll have to be used. Remember this is and IDI 94.5 With the turbo thrown on from factory. Please help me locate this ting. THANKS GUYS
