Big Oil and Big fuel not so big..
Rideracelivemx7
Montana
Hey guys im not sure if i'm over reacting here but let me try and explain whats going on.
So back in late April I purchased some goodies for my truck as I pulled the motor to clean and add some power. (It was just fine before)
I sent my injectors in to be built to 350/200s(from the old 250/100s) by Cass .
I had a set of low mile heads redone, decked, valve job and clean up blah blah. Cross over tube, melling lpop and a few other small things.
When I got the truck together and running it idled ok but when driving it seemed to buck. after a series of reburns we decided I just didn't have the oil(t500) to fine tune the truck.
Fast forward 2 months later I have a set of twin terminators installed as of last night and to be honest I notice zero difference between how it ran before and how it runs now. It starts a little faster now but it doesn't accel any faster, doesn't seem to have more power or pull harder. It doesn't seem to smoke as much as I thought it would with this size injector either.
With these hpops installed shouldn't I notice a difference right off the bat? hell my old tunes drive the exact same in the pedal as well, its not any more responsive.
I have 2 tuners on the same chip and the truck has similar symptoms with both files, bucks and just doesn't seem to have the power that it should with this set up. Anyone have a single idea? I have 2 superduty pumps in series for fuel pumps plumed with stock lines on the block still, do they need to be bigger than the 5/16s or 3/8s that they are?
Gearhead
Series on the fuel pumps? Have you verified that you are maintaining fuel pressure at WOT?
Rideracelivemx7
Montana
only other thing that I noticed is(even with a new IPR in the termys) my throttle pedal still does what I did even with the 250/100s and 5spd. If you hit the skinny anything past half throttle looses its sensitivity big time for the first 1/3 throttle until you flick the key back real quick to restart it. This is every time and I was hoping it was my IPR
Rideracelivemx7
Montana
Matt that's my next step is to put a mechanical guage in the cab. and I ment in Parallel for the fuel pumps not series, my bad
Austin, Tx
Like I've been telling you for at least a year. You've got to get some diagnostic equipment if you ever plan to figure these things out. I would like to know what the ICP and fuel pressure is doing..
As far as the throttle pedal goes, have you tried replacing it with a known good pedal assembly? In other applications I have seen TPS voltage be fine at idle, but after cycling the TPS, the voltage starts jumping around a lot and drops off at idle causing slow throttle response and bucking under part throttle. I would check TPS voltage with the key on, engine off and then again with the key on, engine running. I've also seem them be fine with the engine off, then act stupid with the engine running. Again I've never seen it happen on these trucks, just other applications.
dirk0
Agreed. Fuel and oil. You'll need new tunes and possibly live tuning to sharpen those injectors. The pw and pressure on the tunes for the old injectors are probably way off now.
And 2 pumps in series? One pushing the other??? They should be in parallel pulling from a 5/8 sump or pickup tube.
Rideracelivemx7
Montana
They are in parallel sorry, I need to edit that. I have the correct tunes but what I ment by old ones is the tunes for the single pump vs the dual pumps. I'm going to be running a contribution test to rule out Injectors.
Hell I might just have the worst case of air ever. Drives me nuts though
do not put a mechanical gauge in the cab....if the hose lets loose or the gauge craps out you will have the smell of diesel in the cab for a very long time... use an electric gauge if you can swing the price... if not ..mount the mechanical gauge out on the cowl.. I did mine with a piece of 1-1/2" PVC for permanent use..but you can run a hose out to the cowl and tie the gauge down to the wiper just for testing...
dirk0
DiPricol had an electronic unit (good luck finding those now) and someone made a electronic unit.. Maybe ISS or Autometer.
Austin, Tx
I run an Isspro electric fuel pressure gauge on one truck and an Autometer electric fuel pressure gauge on the other one. Both had sending unit failures within the first 500 miles, but after replacing both sending units that one time they have both been very reliable.
some day ill get one for in the cab...right now i got spend time with my kid till he goes off to boot camp... then i can go to work on getting this motor in...he will be stationed in GA.. I'm hoping to take my truck to graduation and have her live tuned by some body... i wish gearhead was a little closer to there..
Rideracelivemx7
Montana
i had glow shift elecric fuel pressure, zero luck with them.all my other gauges by them were flawless but the fuel pressure gauge and sending unit were replaced several times. would be fine for a week then peg out at 100.
Tom S
If it was mine I would be watching ICP, MAP and TPS on a scan tool for sure.
dirk0
I wouldn't ever use that brand. I've heard nothing but bad things about them.
rascal
TX
I just ordered the ISSPRO EV2 boost,egt,elec. fuel pressure set up. I have heard good things about ISSPRO. Plan to install next week.
Rideracelivemx7
Montana
ran the truck to work today and this thing ran terrible no matter the tune. Is it possible I have air in the lines after 50 miles still?
dirk0
Air in the system? Doubt it. What is your ICP readings and IPR voltage\duty cycle?
