sunrisefordparts
Parts for an 08 f250 4x4
Front wheel bearing assembly for driver and passenger side
Steering gear box shipped to 37330
Thanks
hub bearing assy list $634.13 each sell $456.58 each
gear box list $590.43 sell $460.54 w/exchange
shipping $25 for both ways
q#299858
Tom S
2006 Taurus 3.0 Single Cam Vulcan motor VIN U 1FAFP53UX6A236181
Coolant bottle
2003 Taurus 3.0 Single Cam Flex Fuel VIN 2 1FAFP55283A237305
Transmission Filter FT-130?
Fuel Filter
Transmission pan gasket only if the OEM one is not reusable
Washer Hose Kit 3F1Z-17A6-05AA
Trunk liner YF1Z-5411600-AA
Is the shipping still free except on heavy or oversize items? If you have to order the trunk liner and it will take a bit that is fine although I need the other items this week.
sunrisefordparts
Coolant bottle
Fuel Filter
coolant bottle list $65.33 sell $47.04
q#299874
trans filter list $34.44 sell $18.60
fuel filter list $27.38 sell $14.78
trans pan gasket (facotry is moulded reusable) list $37.55 sell $27.04
washer hose kit list $16.00 sell $11.52
trunk liner list $99.99 sell $76.99
shipping $10 for the length of the cargo liner box.
q#299875
old96stroker
just south of kansas city
Need to rebuild front end on late 1999 f250 7.3 4x4 ecsb pickup. Need wheel bearings, ball joints, all tie rods, sway bar links, axle seals for auto hubs and leaf springs-i believe I want heavier code front springs to level the truck out, it noses down pretty hard. Thank you.
sunrisefordparts
heres you quote bud.
  • Q299956.pdf
Tom S
The Orange high temp O-ring that goes on the EGR bracket/tube where it connects to the plastic upper intake manifold. I will attach a photo if that will help. If you could post up a part number that would help me as well. If you have this in stock would it be possible to just mail in an envelope it so I have it here before the weekend? Sorry, I missed this one or it could have gone in yesterdays order.
Tom
sunrisefordparts
Tom
i dont have one in stock part # 1f1z-9j469-aa list $10.48 sell $7.55
njjeep
Brick, NJ
Can I have a quote for a 2001 F-250 4x4 7.3
2 - Front Wheel Hub "Unit Bearings" with ABS
1 - Power Steering Pump
1 - ICP Sensor
shipped to 08724
Thanks
