Tom S
pump 3f1z-9h307-bb list $506.80 sell $364.90
oring f6dz-9276-a list $11.64 sell $8.38
lock ring f7dz-9c385-aa list $12.53 sell $9.02
as for the extended range was only available on ealry production flex fuel, oring coming with fuel pump is hit or miss with ford.
q#306640
I guess I better add the fastners for the fuel tanks straps to this as well as the car was back east at one point and has some rust underneath. I think it will be a bolt and a U-nut.
Thanks for the scoop on that extended range BS
sunrisefordparts
the bolts list $4.11 each sell $2.47 each
foldover nut list $2.05 each sell $1.24
same q#
Tom S
same q#
Part numbers would be awesome so I can order off the site.
FYI all my other stuff came yesterday from the black friday sale. Thank you that was quick and efficient.
duddy
sloshkosh wi
:cursing:
How much would the coolant resivoir or an 08 f250 CCLSB run, and what would be the shipping cost to get it here by Friday, I will be placing order Monday morning i you can help me out. Apparently mine leaks at the seam when it hits 0 outside.
Edit, since I am in there, tstats and gaskets need to change them. Egr coolers are deleted from the truckso anything needed because of those I can pass on unless its a kit.
Found that you qouted this for me quite a while back just wasnt sure if it still legit.
degass bottle list $169.78 sell $127.33
sunrisefordparts
heres the numbers for the bolts and foldover nuts.
N801107*S410
N804568*S190
sunrisefordparts
:cursing:
degass actually went down a couple bucks, sell $125.50
tstat w/seal list $36.19 sell $30.40
shipped on both
q#306896
