Retrofitted 6.4 headlights
nickg3130
West Long Branch, NJ
Does anyone have any pics of retrofitted 6.4 headlights? I'm still on the fence about doing them to mine while the truck is down. I know light output is great and I love the way the look on the newer trucks, but I haven't seen enough on the 6.4s yet to be convinced.
verifine
London, Ontario Canada
[/URL][/IMG]
[/URL][/IMG]
Poglife
Georgia
Here is some I have pics of. Don't know nothing bout them or whose truck they were off of but I like them
Cory@RPHC
For ease of install I'd go with mini stage 3 h1 kit. Screws right into the existing hole and it overall FAR easier to aim
k2xp
Is the light output good enough or do you need to run the fog lights all the time??
FaSSt9602
Gilbert, AZ
I just saw these on the retrofit source site. Are they as bright as the fx-r's?
The new mini 6.0's are pretty damn impressive. Some purists that will only work with OEM retrofits aren't a huge fan, but they put out awesome light and a nice sharp cutoff if properly installed.
AllGo'N'Show
West Canada
I like verifine's all black housings, just not sure what to do with the amber as it will be the only amber left and it isn't my favorite to start, that's what I've been trying to find pictures of if anyone else has some saved.
AllGo'N'Show
West Canada
Work truck White with black accents, thinking white reflector, maybe with F350 on it like the new F150's but then I thought that's trying too hard
nickg3130
After doing some more research i feel that the mini h1 kit is the way to go. I like how they are smaller than most and require little to no trimming or drilling.
verifine
Thanks for the compliment, I will most likely end up smoking this reflector with a coat or two of niteshades once spring rolls around. I am also kicking around the idea of doing another retrofit with the Acura TL projectors. For anyone on the fence about trying a retrofit just go for it. I am not a person who is good with projects like this but I took my time and checked and double checked everything. Everything turned out great!! Check the retrofit sources youtube channel there is a lot of helpful videos to get you past and issues you might have.
