Build time! S400 style
617mach 1x
Well guys I'm getting ready to start my build in 2 weeks, as soon as I finish my block 4/red seal in autobody
Anyways the truck is an 05 xlt f250 Eclb it's been
Studded
Deleted
Ported intake, egr completely removed
190/stock
Fuelab fuel system
Running on 325/65/18s, 4linked, traction bars
Built pretty everything myself looking to finish it up this summer
Parts I already have
FMW S467.7
Spare motor, trans transfer case
Everything to build my custom sets of manifolds and up pipes out of 304l
Tial Wastegate
4-10 gears and lockers
I'll be working over/porting the heads, also going to use a cam with this setup
Truck is an all around truck for me weekend warrior, sled pull , drags
I'm probably going to use the HDP level 2 trans rated for 850hp but what stall should I look at getting?
What size injectors? 285/100? Hybrids? Conventionals? Dual hpop?
Sorry for the long post
JGman141
Ohio
I really like my 285/100 conventionals with full icp but I think that might be a little to much fuel for an s467. Maybe look into a 255/100
617mach 1x
Thanks, only reason I was thinking. 285s is I can go bigger turbo later on like a billet 475 or a 480 clipped with a 2.6 cover for pulling
Anyone else have any suggestion? Got be some more
BlueWaffle
Grapevine, TX
i have 255/100 hybrids and it's plenty of fuel for my compounds. people think that just because the throw huge injectors in their truck that it's going to make a ton of power. a PROPERLY matched turbo/injector combo will always outperform (IMO) a set of firehose injectors and a mediocre turbo setup.
617mach 1x
Yes, a single turbo isn't as efficient as a compound but I can't build twins do to sled pulling rules!
Only reason for 285s now would be I wouldn't have to upgrade later on, although I'm sure 250s would get me to my power goal for now
I did get the turbo sitting in it's place last weekend
617mach 1x
Right now it has the 1.1 divided housing, going to order a .9 for it
83.5 inducer 74mm exducer
Pizza pig
In the Brig (Banned)
MD
they come standard with a 1.10 T4, but optional .90 or 1.0 housings are available. 83/74 Turbine
617mach 1x
Yea bought mine used, few track and dyno runs, he was running it like it came for BW
617mach 1x
Had them cut at my college, on their water jet while I was there finishing up my license, it was a full flange but ended up cutting them into individual piece because of fitting issues
617mach 1x
All done the fitting together part
617mach 1x
Yes it does. Running a custom intake setup too I see?
Huh? Are you seeing the passenger side manifold sitting up there?
Yea I think that's what he seeing, in the first pic Mdub? That would be the passenger manifold
I did port my intake manifold last year tho
And I build a fuelab fuel system for it last year also
Fixed those rust spots under the truck also! Damn salt roads during the winter just eat the truck
The truck it's self
