Progress thread
swinky
Eastern, Nc
Wow, electric boost. Fancy!
I'd run off the elbow with some poly tube and tuck the sensor out of the way. I have always had weird readings off the MAP sensor.
Vacuum hose will work right? Or do I need the compression fittings? I'll change over to compression eventually just having a hard time finding it. Gauges are going to be very different. I'll have pics tomorrow.
Sent while buying coolant
swinky
Eastern, Nc
Gauges are done.
swinky
Eastern, Nc
Those two combined with the scangauge.
swinky
Eastern, Nc
What's the best way to clean injectors? I'm putting new o-rings all the way around. Just give them a quick wipe down with clean oil? Do I need to avoid getting oil in the little fuel ports? Or grease?
Sent from my SM-T210R using Tapatalk
swinky
Eastern, Nc
Updates, hows it running with the new setup?
Runs great trapped 83-84 at rudys. Couldn't get it to spool though. Need a new air filter and I gotta start searching for leaks. Might do a cast borg wheel to get rid of this 11 blade billet. The guys at mpd swear by the cast wheels. Hopefully get everything worked out and hit the track on sunday.
Extended Power
You must have an exhaust leak........anyone can spool a 66/73/.90 with divided up pipes.
04cr450
harford county, maryland
^were you pulled over Saturday night on interstate 85? think we passed you heading back to hotel from the event. If it was you hopefully the cop let u go?
swinky
Eastern, Nc
Yuhpp got me for 80 in a 70. ****in bull****.
swinky
Eastern, Nc
He coulda hit me with a lot more if he wanted to. I wasn't hammered but probably above legal. So I can't complain.
swinky
Eastern, Nc
Updates! Truck went 8.9 at 84. Couldn't get it to spool with a plugged air filter. Sump is going on this weekend and hoping for a nice 12 second pass on sunday.
