Swagger Build thread
rat49f6
Vernon,NJ
Was tired of looking like a method addict from welding upside down so the frame went on It's side today
Sent from my SGH-M919 using Xparent Green Tapatalk 2
is the trucks weight going to be drastically different than stock?
rat49f6
Vernon,NJ
Yeah probably quite a bit heavier ... I'm over building everything
rat49f6
Vernon,NJ
Truck officially has every bolt and nut off it. Fish plates are being finished welded in today. Zac is at the shop right now curing his senioritus with some paint prep on the frame. I hope to have it in primer the next day or two and paint by the weekend.
Ps anyone who doesn't get why a truck cost $60k swing by I'll show you how many bolts a sd has
Hotrodtractor
Mingo, Ohio
I want to check this thing out in person when you get it all back together. I know how much work it is to take something down to a bare frame and start over with the suspension and I can also tell you that this is more work than I have in my Dmax. Mad props to the DIY guys, I love it.
rat49f6
Vernon,NJ
Thanks hrt means a lot coming from a builder of your caliber.
rat49f6
Vernon,NJ
Frame is pretty much stripped ... but now I found weld in tank bungs that I'm waiting on
The pass side air line is routed outside the frame rail so the exhaust doesn't melt it. Well I wasn't happy with the line straight thru the frame so weld in bungs with 90 deg fittings should make for some over kill bulkheads.
Hoping to still have some form of paint on the frame over the weekend
rat49f6
Vernon,NJ
Parts are everywhere ...wish I had them in one place to take a pic
rat49f6
Vernon,NJ
Street a few set banks the frame is finally 100% primed
Paint tonight and tomorrow
rat49f6
Vernon,NJ
Lol damn auto correct
After a few set backs the frame is finally 100% primed
rat49f6
Vernon,NJ
Frame is painted ... Think it looks great
rat49f6
Vernon,NJ
Yes everything is custom built by me and friends
Update: its a roller again. ..
6 link bolted on, front control arms on, bags in, air lines plumbed and mounted, tank and valves mounted and plumbed ... All new bolts on everything
