If you bought a CPS from Ford I would suggest you to get a Delphi HT101G and get the engine running the way it was first designed to.
Ok, so the problem is not fixed. Its now worse. None of the Ford dealers were open so I took my chances with an Oreilly's BWD sensor. The truck will barely start sometimes and completely goes tarded when I turn the windshield wipers on. I guess that's somewhat common with the aftermarket sensors. So anyway back to the original sensor until tomorrow when something is actually open. Goddamn what a pain in the ass. At least its easy to swap but jesus. Does this sound normal to you guys? It will be running fine then all of a sudden just die for a split second then come back to life. Especially when I'm over half throttle usually about the time its going to shift. One time it died and cranked forever before it would start. I have to drive it from Detroit to Houston tomorrow and I sure hope it makes it after I put that new sensor in.
Tarm, when you say Delphi, where are you getting that one? Is that the Ford brand?
