Snoop
Had an 03 excursion in we did head gasket on and other preventative maintenance things to. Everything went well but had a ICP sensor fault when I initially finished the truck. Unplugged the pigtail and plugged it back in and the CEL and code went away. Customer took truck (ran great no codes) and drove home 100 miles. He said he was almost home and it started dying on him. He pulled over and it started up every time. Still same thing today. Does it hot or cold. He said motor never misses or lopes or sputters. Jut loses the petal and then engine is off. Pulls over and starts right up. Local mechanic was able to pull codes for crank position sensor and can position sensor. Kind of odd... I'm thinking its the ICP sensor/ and or connector for ICP. What else could it be? I wish he was closer then I could throw it on IDS and get some data.
