gwunter
Just picked up an 05 with unknown issues. Appears to be bone stock from intake to exhaust tip. 260k miles. I have a crank but no start issue. I have a code that points to the ipr, but I don't know if it would cause the no start. I have checked the ficm, and my results check out good. I have no smoke of any color out the exhaust while cranking.
The guy I bought it from thought it had bad head gaskets because of white smoke out the exhaust while running, but it has never puked out the degas. Still has an egr in place and assumed functioning. I'm assuming nothing has been updated as far as stand pipe, dummy, stc, etc goes. Here's a couple pics of forscan logs. This is probably on a 10-15 second crank. Any thoughts on where to focus on would great. I dont know if bad o-ring seals on the hpo would still only generate such low psi, or if there's a bigger issue.
Sent from my SM-G970U using Tapatalk
