05+ camber settings
lariat 7.3
i see that it needs to be 4.5 degrees to keep the thing tracking straight. Currently have a 2.5 level, will the stock adjusters be sufficient or do i need to order different ones?
When i originally did the axle swap i told them thats what i wanted but they set it to "factory" specs. It handles worse than the ole leaf spring front end
Camber???? Wheels straight up and down has always worked for me...
I trust you are speaking about caster. 3.5* is usually plenty. You will need to do radius arm drop brackets or alignment cams to achieve it.
lariat 7.3
Correct. So I do need to order alignment cams omreplace the stock ones
not sure what that is in the link you posted. You want the cam that goes over the ball joint. any alignment shop that is worth their salt should have them in stock and know when you need them.
