PDT1081
I may have missed it, but what are the dimensions of the nDash and nGauge?
nDash
4.3" 480x272 Color LCD
I'm more wondering what the overall dimensions are. Length, width, height, etc.
What is the reasoning for only programming over stock tunes?
My pickup was deleted by the dealer i purchased it from, but i dont have the ability to return to stock. He uses h and s xrts then just puts a stock power leavel dpf deleted tune on and sells the dpfs. I was fully aware of all of this and for the price i paid i could have cared less. I Spoke with spartan customer service and they told me that i would have to take my pickup to a ford dealer to have a stock file flashed before i could tune a spartan file on.
Similar or same as the set up for the 2011-2012's? I liked the fact I did not have unplug everything under the hood to have things work. Just don't like have open plugs to corrode.
Matt would need to clarify on the 2015, but the updated 2011-12 tuning, as well as the new 2013-14 tuning, will have some new EGR delete functions (ECT2 sensor now shut off for example). Those who wish to install an aftermarket intercooler pipe will also be able to do so with the new tuning without having to worry about a code and reduced power mode due to removing the throttle body.
The stock file is very important "if" you ever need to visit the dealer. They plug in their diagnostic stuff, find the file you have foes not match what Ford has on file for a stock code. Their computer goes into full on lock out/ down mode. And if the tech is not paying to close attention it will send the info strait to Ford. Then all bets are off. Even if you went in for a simple oil change and happen to plug in.....
Stock file is real important
Yeah.....no. I've had my IDS, always the latest updates, plugged into quite a few deleted 6.7s and this doesn't happen.
The only thing that can happen if you take your deleted truck to the dealer, and the tech is a complete idiot, is they flash over the delete tune with the latest update from Ford. This will only let the truck start once if the temp sensor are unplugged, however, the ECM is not locked out or anything. Simple reflash of the delete tune and the truck runs again.
which they can't do if the truck has a Spartan tune loaded because Spartan re-names the strategy.
H&S and SCT are undetectable in that regard save for the fact that temp sensors will be out of range, monitors won't be set, etc.
Hey Mike!? If a guy wants to sell his Livewire with the delete tunes that you so kindly provided, is it possible to sell the tuning with it if it goes to another 15 with just an update on the strategy?
yep not a problem. it should be free for the new puchaser , depending on the ecu strategy and updates.
We are adding TPMS support along with tire size changes with the 6.7L after the update. Would like to integrate it into the release, but just too damn many things to get done in the short amount of time.
