do you have to do a trans relearn on any tuning whether its deleted or not? didnt know if it mattered any?
567 stock turbo with modified turbine side.
It was a 63mm fleece used with the larger turbine. There is no way in f*ck the factory compressor wheel can move that air. If it was a factory cast wheel then the dyno is junk....
wouldn't the larger turbine make up for it by getting rid of the fuel faster at full song?It was a 63mm fleece used with the larger turbine. There is no way in f*ck the factory compressor wheel can move that air. If it was a factory cast wheel then the dyno is junk....
He told me it was stock compressor side. Doubt he's lying. Maybe the Dyno is junk , who knows.
we talking turbin housing or wheel?Yeah maybe it was. I was only going what I heard on the internet. Heard 63mm cheetah... But you know how the internet is.
A larger turbine will only bleed some more BP. It does not make more air on the compressor side. The larger turbine will also change spool characteristics to some extent.
Ahhh 10-4Wheel. Housing change is for the most part never gonna happen.
Ahhh 10-4
larger turbine will drop bp , which on a 15 seems to be an issue , less bp can and usually does equal more power.
39/70 is bad .
The video on you tube is titled 2015 Cheetah turbo testing. on Brayden's page
Guys,
I was curious with the SCT X4,Can you lower the pressure for the TPMS sensors?Im running 55 in my rear and have the stupid TPMS light on and would love if I could change the psi in them through the tuner.I haven't made it home to my package yet to read if I could so that's why I asked here!Thanks guys!
Charles
just ordered all my stuff today so I'm sure you'll be sending me and logan some goodies soon mike :bowfast:
got you buddy.shirts too follow, the midget didn't give me your size
