You can put them in and dial the pulse width back, but what's the point of putting nozzles in just to dial it back?
the point is to change where your power is, depending on how you use your truck.
me, for example, i can count on one hand the times i have been over 3-3500 rpms in a year.
power up top is pointless to me, i'm not there, i dont use it, so why set up my truck to have the power there?
hooked to a trailer, i want my power down low. it's where i drive.
and if changing to a 15% or 30% would get me that, and pulling back pw would lose the top end that i'm never in to begin with, then swapping to a larger nozzle is a no brainer for me, or anyone else who uses their truck in a manner like I do.
most people make the assumption when someone is asking bout nozzles, that their after power up top, for dragging, or pulling, or....or.....
for some, thats not the case.
i think when wayne was doing all his testing, or maybe it was JD, one of them has a dyno graph that compares stock to 30%, iirc.
and it showed large though not huge gains down low, and a drop off up top. though that was with the same tune, not with one made for 30% on stock fuel. and those pro's and con's were enough to make me want to do it to my truck. the rpm range it lost power in i'm never in, and where it had the most gains, is my rpm range daily.
even if you have a tune made to make use of 30% on stock fuel, you would still lose up top, though not as much as not making the changes. there are graphs floating around in here somewhere that shows all this, but i have not been able to find them again, but i remember seeing them.
i believe even dustin is on a larger is better kick, when it comes to nozzles. granted, his is with dual fuelers, but i remember reading him saying anything less than 150's(whatever % that is) is a waste. he would rather tune back a larger, than run a smaller.
