The majority of my towing is a 18ft trailer with two 1900lb mowers on it. So I'm never really towing that heavy. I have towed heavier on occasion, but it's always local, and short trips where I'm not worried about it too much.
But I get what you guys are saying. It really would make more sense to just replace with stock size and be done with it, since I'm not really looking to upgrade a turbo in the near future... or even other supporting mods at that. Like I said, I'd just been tossing the idea around. But more than likely, I'll just end up with some stock replacements and call it a day.
My current injectors aren't really bad. Just some pretty bad stiction. I've tried Revex and Archoil.... neither of which helped all that much. I get weak buzz tests on a couple of them, so they are just ready to be changed. No big deal. I figure I've gotten 155,000 miles out of a stock set (pretty sure they have never been changed), so they've held up better than most. I keep it plugged up when it's cold and I never have a problem with it. It still cranks even when not plugged in, but she runs like hell until it warms up some. Just tired of fooling with plugging the thing in every night, or waiting on it to clear up if I can't plug it up some days.
Not for nothing, but how good are your batteries and have you tested your FICM yet? You'd be surprised how crappy things will run with a weak FICM.
Great comment. When I used my extreme tune to tow, I had the lowest temps period, but I had the most advanced injection timing! There is a reason tow tunes do not advance the injection timing too much, especially if you load the engine for longer bursts (cylinder pressure). With his stock nozzles, his risk is definitely lower.
Same here. I towed a 14" enclosed trailer once on X-street, and gave it all sorts of hell running up hill. My EGT's never got out of control, but the coolant temp on the dash gave me some warnings and defueled the truck. I had to pull over and let it cool off a bit before proceeding. Again, EGT's were always in check. I don't think they broke over 1100*.
I can hit that on my tow tune too, but I never have to worry about EOT or ECT.
