jimmyz32
I am on the fence about the 64mm non VGT or the 68mm VGT for my 190/75%. I do tow about 5k every day. Thanks for the write up.:thumbup:opcorn:
Ok....tunes from RCD and Innovative are in. Stay tuned as I'll be trying them out over the next few days!
Thanks again for all your help Jared and Eric!
I just can't believe your stock trans has held through all of this... you should be pushing 600hp I would think with this new turbo.
don't jinx me bro! i drive like a puss 98% of the time so I'm sure that's why it's lasted. Matt is going to bring his spare 5r down to ennis so I can really beat on this thing to see what dyno and track times are :thumbsup:
Ill be running at the test n.tune Friday night. Saturday is drinking day :blitzed:
highway cruising with reg powermax they were about 850-900. now they're 750-800 ish.
as far as power goes...the wheel is 4mm bigger so down low at low throttle, it's not going to feel any stronger. if anything, it won't feel as responsive as a turbo with a smaller wheel. it does pull harder when over 1/2 throttle but it's most noticeable up top. when you put your foot in it, it pulls damn hard. keep in mind, i'm still running my old tune for the reg. powermax so once I get it all dialed in, we'll really know what it does. stock trans will not last too long if you beat on it with this setup.
