1994.5 F250 7.3/5spd Project for sale
TheSmokinStroke2002
Hadley, Michigan
1994.5 F250 project for sale
-7.3 power stroke (was told 20k on rebuild no papers. one of the best running 7.3's ive been around)
-5 SPD transmission with luk single mass flywheel conversion, New hydraulics, New throw out bearing, new pilot bearing, new clutch fork. Clutch is new but had minor rust so i can not guarantee operation of it.
-Dana 60 front axle
-Dually rear axle
-4" suspension 3" body lift
What it needs:
-E-fuel system plumbed and wired (Has regulator, lines, pump, filters)
-Interior put together (have everything including brand new vinyl mat)
-Drive shafts installed
-Brake lines ran for whole truck
-Wiring behind cab ran (have full harness just needs spliced)
-Misc. Wiring I'm sure will pop up along the way
I have mostly every part to put the truck back together. I got it as a project but I want it gone. It needs more time than anything which I do not have. Could be a very nice truck. I have a bed for it but it has a dent on the passenger side.
I am asking 3k for it. I will not part individually.
Will consider trades for quads or snowmobiles.
Links to engine running:
http://youtu.be/8KA9GV-mhp8
http://youtu.be/80Poa_XY_uM
Located in Hadley, Michigan.
Vogel469
How many miles are on the body
WILD_PHIL
East TX
How big a tire did you plan on running on this?
E99 F350/zf6/guages/arp/comp/stellite/ billet wheel/ bellowed... Need more fuel and more air.
