1994.5
1994point5
So today I went out started my truck and lit it run for a minute then before I could put it in gear it shut off. The check engine light flashed a couple of times then stayed on. I cycled the key and the light flashed again no wait to start light or anything. The truck would crank but wouldn't fire won't smoke. So from what I read on other posts I figured the CPS was bad so I went out and replaced that only for the same thing to happen. I changed tunes and it fired again and died shortly after. Any advice or tips would be greatly appricated
Justin@DP-Tuner
I pulled the ts out and it starts and just I just have a miss now
Sounds like there is an issue with the chip.
Has your 94.5 been flashed to an OBDII compliant code yet? If not, we can do it for you. This will enable you to connect an OBDII scan tool to the truck and monitor some PID's, as well as read/clear codes.
