Dieselfever
This is my brother's truck he is selling: It is a Red '95 F350 Crew cab long bed.
*It was an auto and he swapped it to a 5 speed, it has a South bend OFE clutch and the trans was gone through before the swap.
*Has a 4" suspension lift with 35" tires, I would say the tires are currently 60%.
*The front end has been rebuilt recently with new ball joints, tie rods, u-joints, new steering box.
*He recently swapped a Disc brake Dana 80 out of an '01 Dodge in the rear, it is 3.55(so is the front), new brakes on it, ladder bar brackets with ladder bars installed. The speedo is hooked up and works correctly also.
*The engine has a set of Baby swamps that are about 3-4 years old, Electric fuel system using a Super Duty pump with pre and post filters, 66mm drop in OBS turbo(comparable to a D66), TS 4 position chip with Swamps programming.
It is starting to rust on the rear fenders where these trucks do, but isn't bad yet, the truck itself has just over 380K miles on it but as you can see a lot of things have been replaced to maintain it. He currently drives it everyday to and from work(approx 20 miles each way)
He is asking $8000 OBO To inquire call Joe at (859) 446-2808. He is open to offers
