rusty1161
This truck was built to keep forever, but my plans have changed. I’ve listed every mod/upgrade I can think I’ve done over the last 9-1/2 years. It does have a small oil leak at the rear main seal, the flange wasn’t sealed well when it was replaced and it has what I believe is a clunk from the infamous loose front crossmember rivet. Pics to follow.
$16,500.
260,000 miles
John Wood Towmaster E4OD,
kingpin Dana 60 front axle,
2001 10.5” rear/disc brake/8 on 6.5 hubs,
3.73 gears
Trutrac rear
Sky 3” RSK, SD springs
B code rears
Fox Shocks front and rear
PMF trac bar
Irate T4 kit
SD aluminum intercooler
363 SXE turbo
PIS 160/30 singles
SD UVCH and gaskets.
Mann Hummel Provent 200 CCV filter
Hydra
Swamps HVHF IDM
Isspro trans temp, coolant temp, EGT and boost gauges. Scan Gauge Interceptor with EGT and fuel pressure.
Strictly Diesel regulated return fuel system, SD pump on Irate bracket with 2 mic and 30 mic filters. Spare filters and pump included.
Fluidampr with SD water pump pulley.
Hydro boost brakes, correct F-SD pedal.
New Ford A/C compressor and hoses, new drier, blows cold.
6.0 fan blades, dual idler upgrade.
New battery cables, batteries are 8 months old.
DC power 185 amp alternator.
Stock 40/20/40 front seat with 2005 folding/platform rear seat.
Tool box in bed
ARE DCU camper with barn doors included with factory tailgate
Class 3 hitch and airbags installed.
Thanks for looking.
Rusty
$16,500.
260,000 miles
3.73 gears
Trutrac rear
B code rears
PMF trac bar
Irate T4 kit
363 SXE turbo
PIS 160/30 singles
Hydra
Swamps HVHF IDM
Tool box in bed
Thanks for looking.
Rusty
