1999-2004 Super Duty Track Bar Repair Bracket
noslofivoh
Loganville, GA
Lower Trackbar repair bracket for 99-04 Super Duty. I purchased this to repair my buddies truck but he ended up trading his truck in. I used this same kit on my truck to repair my broken lower track bar mount. To install, simply cut the old lower track bar mount off the spring perch, remove leaf spring U bolts, install this against the lower spring perch and reinstall U bolts and torque to spec. Hardest part of the job was cutting the old bracket off. I accomplished this with an angle die grinder with cut off wheels. Took me less than 2 hours total from start to finish. This kit is makes the mount much stronger. Works great. I paid $125 for the kit and having it welded up. Asking $75 shipped.
