# 2 Relay Shuttering
TURTLE
OHIO
My truck will not start. It a 97 7.3L. I turn the key and the dash flickers on ond off even the WTS light. It clicks on and off really fast and so does the #2 Relay under the hood. It wont stop actuating. I switched the relays around and it still does it. When I turn the key it sounds like the starter does the same thing like its locked up but just goes clicks/shudders. What could this be? Thanks.
Redpower
Central Iowa
:whs:
You need the full 12v on each battery to get the truck started. I had 8v on one and 12 on the other and my truck did the same thing.
TURTLE
OHIO
I cleaned the terminals and jusmped it and it worked. Sounded way worse than that....
