dsberman94
Pennsylvania
I'm trying to put an amp and subs in an escape. I've got the vin number. Is there a factory harness that will allow me to do this or will I have to tap into the existing harness? Could it have the correct harness in it already? I haven't torn anything apart on it yet. Looking for the proper way to do this with an OE first before I ask google. Last 8 of the vin are CKA34388. Thanks.
hiniker88
Mandan, ND
top end kit list $664.74 sell $518.50
bottom end kit list $26.55 sell $20.71
q#393597
Ok so I need front cover gasket and seals, front main seal. Oil pump seals. Rear cover seals and rear main. Also need a dipstick, thermostat, plus that bottom end kit. Will also need oil filter. And a water pump.
ccmac
Texas Panhandle
I'm in need of what I believe is called the Waste gate actuator solenoid for 2012 6.7. From what I've been told it's a common issue.
sunrisefordparts
there isn't any harness through ford, but most stereo shops can get a pigtail that will plug directly into the factory harness then from there you can splice into the radio harness and not have to hack up any factory wiring
sunrisefordparts
heres your quote.
  • Q397098.pdf
248superduty
2006 f250 front coil springs and isolators, 2008 f250 rear springs. truck is an 06 f250 4x4 with 08 rear springs. im looking to get back to stocks ride height. Shipped to zip code 48220.
sunrisefordparts
on the front coils I can get the spring code from the vin, on the rear leafs its more or less going to be a shot in the dark on getting correct springs.
Lugger007
Ct
Need to replace radiator and coolant bootle & any associated parts to do the job
2012 f250 diesel
Thank you
sunrisefordparts
2012 f250 diesel
Thank you
rad list $750.00 sell $585.00
degass bottle list $268.88 sell $193.60
possibly just the orings for the hoses being changed with the rad. looking $220 for the orings
shipping $25
q#397856
Lugger007
Ct
shipping $25
q#397856
Thank you. How about the houses too, that way I won't have an issues again?
248superduty
ok Im honestly just looking to drop back down to stock height. ill get the vin for you tonight or tomorrow.
sunrisefordparts
upper hose list $123.47 sell $66.67
lower hose engine side list $115.58 sell $62.41
lower hose rad side list $125.53 sell $67.79
and the oring price I gave you was $22 not $220, but if you go hoses they come with it.
