mrplowjr_Ez_v
- Joined
- Jan 26, 2012
- Messages
- 71
- Reaction score
- 0
http://rochester.craigslist.org/cto/2985246460.html
2000 Ford F-350 XLT 4x4 Powerstroke Diesel 197,000 mi $6900/obo
Included addons:
BTS BUILT Transmission with Precision industries Torque Converter ($4800)
BDP 160cc Stage-2 Single Shot Injectors (Beans Diesel Performance) ($1650)
Custom tuned chip (4 Position) ($450)
4" MBRP 304 Stainless Exhaust ($475)
V-10 Trans Cooler ($250)
8' Fisher Plow with 2 years on rebuilt pump (New motor/Resivor/Filter)
407 hp 849 ft/lbs on a Superflow (This truck has been down the track ran a [email protected])
Features:
Power Windows, Power Locks, Cruise, A/C, 4x4, ABS 3:73 Limited Slip Differential, Fisher Plow Frame and Wiring (Plow Available), Tekonsha p3 Trailer Brake Controller. 4-steel wheels and snow tires (+/-50%), 4-Aluminum wheels with summer tires (+/-25%), 1 spare steel wheel and tire. Off Road Package, Sliding Rear Window, Heavy Service Suspension.
NEW:
Oil Change 5/5/12 (Shell Rotella)
2 new batteries/Cables 4/10/12
New Oil Cooler 5/2011
Air Filter (Baldwin PA-2820) 5/5/12
Alternator 10/2011
Starter/Solenoid (recent) 5/2011
Brake Pads, Calipers and Rotors all the way around. 4/10/12rears 10/2011 Fronts
10k on rebuilt turbo
Fuse Box 4/10/12
60k on transmission & injectors
Injector Driver Module (IDM) 4/10/12
Generic Electronic Module (GEM) 4/10/12
Water Pump/Hoses 5/2011
Belt/Tensioner 5/2011
This truck has been a plow truck all its life. It is in pretty good condition for a work truck, but has the typical fender rot The plow could use a repaint and has a small hole in the top right corner of the mold-board.
It also does not come with gauges installed, I have a partial set of ISSPro performax gauges I can throw in with a Pod. I got them and never got the chance to swap them out. I have 2 pyro gauges, Fuel Pressure, Boost. The only thing I am still looking for on them are the senders. I have the control box and gauges.
Photos are available at http://photobucket.com/f350_forsale/
Included addons:
Features:
NEW:
Alternator 10/2011
Fuse Box 4/10/12
