2003 excursion. Torsion bar?
barhopper
Hi all, not for sure about what its called. Straight axle in front and rear. The bar comes off the axle front and rear toward the center of truck (horizontal). Then bolts to a verticle bar. Drivers front is disconnected, looks like bolt fell out.
What bolt should I get?
Anything I should check because of this?
Tia,
Eric
post a pic so we can try and understand what you are talking about. Is is the sway bar perhaps? if so, you can get new end link kits for cheap.
barhopper
Sway bar end link sounds like the ticket. Anyone have a source in or near Salem OR?
yep. Thats the swap bar end link. I hear Ford has dealerships strategically placed throughout the US for selling parts and the like...
Could also hit up the sunrise ford thread on here and see what they would charge to send them to you. Probably quite reasonable.
Jomax
Arizona
Go to Oriellys and get the moog replacements or whatever they have. They work pretty well. And they’re cheap
Jomax
Arizona
It’s not a bolt really. You need to replace the whole link.
Mesa, AZ
If I remember right, only the upper half has the integral bolts, the bottom the,bolts swap over...
