Vodomagoo
My dad is selling his 2005 Ram 2500 Laramie 5.9L Cummins Diesel Quad Cab, 6’ Bed with 142,800 miles
Asking $16,500 obo located in Myrtle Beach SC 29579
Hurts to see it go, Awesome truck with perfect maintenance records. If it possibly needed something changed or updated it was. The truck was a daily driver and lived a pampered life. All parts and fluids were oem unless otherwise noted.
Maintenance log
120,500 miles
• R&R both front hubs
• R&R left & right, upper & lower ball joints
• R&R all (5) tie rod ends
• R&R left & right front U-joints
• R&R front & rear u-joints of rear driveshaft
• Replaced 4 tires (BFG 265/70 R17 All Terrain AT) (3rd set)
• Alignment
110,891 miles
• R&R parking brake shoes & hardware
• both sides, resurfaced drums
• Brake flush
105,390 miles
• Coolant flush
• R&R water pump (coolant thru weep hole)
• R&R upper & lower radiator hoses
• R&R thermostat
• Replenished with OEM coolant
• R&R serpentine belt
• R&R front & rear shocks (Bilstein 5100)
• Wire brushed, cleaned, primed & painted leaf springs,
rear diff., & hitch receptacle (POR15 primer & paint)
97,003 miles (OEM Parts)
• R&R steering damper
• R&R both batteries
90,645 miles (OEM Parts)
• Brake flush
• Cut front & rear rotors
• R&R front pads
• Removed exhaust from CAT back, replaced with
Banks 4” stainless system
• R&R front diff. pinion seal
88,839 miles
• R&R transmission fluid
• R&R front & rear diff., fluids
• R&R transfer case fluid
75,000 miles
• Coolant flush
• R&R all coolant hoses
Note: other maintenance performed &
accessories installed
• Installed when vehicle was new –
factory installed SAE Class IV tow package
with 7 & 4 pin connectors
left & right rear wheel well liners
front & rear mud flaps
bed liner
bed tonneau cover
left & right Westin side-steps
• All manufacturers’ services & inspections,
have been completed at the recommended
vehicle mileage by an authorized Dodge dealer
• Completed oil changes with new oil filter using
OEM products at approx. 7,000 mile intervals -
switched to Rotella T6 (5W-40) synthetic
engine oil following an independent laboratory
analysis of a sample of engine oil I sent from this
engine, analysis completed in Mar., 2011
116,530 miles, analysis results good
• A 4 tire rotation completed at every oil change
• Replaced fuel filter/water separator at every other
oil change (at approx. 14,000 miles) using
OEM products
• After market bumper (Buckstop Truckware)
installed Apr., 2011 with 2 operating 4” lights
• Lubed & cycled spare tire tray periodically
• Air filter replaced as needed (approx. 2 – 3 x’s/year)
• 4 tires replaced Mar., 2008,
approx. 47,500 miles (1st set)
• 4 tires replaced Apr., 2011,
approx. 90,000 miles (2nd set)
Maintenance log
120,500 miles
• Alignment
110,891 miles
• Brake flush
105,390 miles
• Coolant flush
• R&R thermostat
• Brake flush
• R&R front pads
88,839 miles
75,000 miles
• Coolant flush
bed liner
bed tonneau cover
OEM products
