TravisP2001
My 2008 F-350 6.4 Powerstroke has a slight vibration almost like it is a little bouncy when you first accelerate from stopped and when you slow down. It goes away when you are over about 30-40 mph. I checked the rear driveshaft and did not feel anything in the u-joints or center bearing. My next step was to disconnect the front shocks to see if they are bad. It almost feels like it might be bad shocks reacting to the aggressive mud tires on the truck.
At first, I thought it was something in the transmission. I had recently had a transmission line blow out on me when I was pulling my 5th wheel. I changed all the lines out and replaced the filter in the pan. But the vibration does not seem to change at all when gears change or when RPM goes up and down.
Just looking to see if anyone else has had similar experiences or not.
