CMCFord6.4
I have an 09 F250 4x4. The rear body mounts under the cab are toast. The back of the cab and bed clank on every bump in the road so went to the dealer picked up some new bushings and went to replace the drivers side and the bolt came right out and when re installing the new bushing got the bolt tight but there was still play in the cab so went to tighten some more and snapped the bolt in two. I read the torque rating was around 80lbs but I still had play when stepping on the rear bumper? I know I shouldn't just tighten my problems away but the bushing was barely touching the bracket so I only assumed it needed more. Apparently I was wrong does anyone have any info on installing these? Im not having much luck finding info on it. Thanks
