My truck just started having this issue. I had to replace the A/C Compressor and Condenser over the winter as the Compressor clutch locked up and it had damage to the condenser from getting the wrong dryer. I also replaced the Expansion valve as I got a kit that contained everything. Correct charge of Freon and dye added using a machine not cans. A/C works fantastic until it sits during the day at work. Turn it on and the compressor works and the fan locks up. Air out the vent is like 80*. I put my gauge set on it and it shows 30# low side and 200# high. If I wait until the sun goes down and the temp drops into the mid 80's same pressures but 45* vent temperature. It's been a long time since I did A/C work and most of my Experience was orifice tube based vehicles. Neve had much experience with an Expansion valve. Is it possible I have a bad valve?
