2011 F350 H n S EGT issue
WILD_PHIL
East TX
Guy at work recently delet his truck. Full 5”, EGR delet, and H n S. He hasn’t changed the tune from TOW but was told at the shop that he might have issues swapping tunes because he has an EGT reading 2700* on the mini max.
Does anyone know about this and what can be done?
Sent from my iPhone using Tapatalk Pro
Harley-6.4
Try getting a new egt sensor, because I had the problem on my 12’ 6.7 with spar+an tuning on it, I switched out the sensor and it read fine.
H&S won't read a factory egt sensor. You need an aftermarket one.
Santa Fe NM
My mini maxx had two different souces programmed to read egts. Maybe its reading from the wrong source. But like previously mentioned its probably a bad sensor.
