NRHX2009
I have been working on getting a solid built drop in for the 2015 trucks, The plan is to have a line up of the following:
Stage 1 64mm compressor with stock turbine
Stage 2 64.7mm x 92mm compressor with 10 blade 66mm turbine, 360 thrust
Stage 2.5 64.7 x 92mm compressor with GT40 10 Blade 70.5mm turbine, 360 thrust.
Stage 3 68x100.5mm compressor with GT40 10 Blade 70.5mm Turbine, 360 thrust.
There will be some extensive testing done by a few shops before any will be released, Stay tuned for updates and dyno numbers.
Stage 3 Turbo below
Stage 3 Turbo below
