2015 F350 Caribou
VetteD_SiN
nice truck! i have one like your but short bed! didnt like the color at first but it grew on me rapidly. lol
MrGTO
East TN
Thanks
I had an option of silver, blue or caribou. I just like the way the caribou looked in the bright sun.
TripleE44
Keller, TX
Look up the magnuson-moss act. it is very informative. was a lawsuit back in the day that states that in order to void a warranty, the aftermarket part must have a direct correlation to the factory part that failed. so basically if you have a tuned and deleted truck, and your A/C goes out, they have to honor the warranty. but if you melt a piston, burn up your clutch packs, and blow up your charger, it will more than likely not be covered.
The problem with this that people overlook is that the burden of proof is shifted to the customer, not to Ford. So they deny your warranty on the charger because of your tires or shocks or whatever, now you have to find a way to prove it didn't cause the failure...
MrGTO
East TN
The big issue is, do you have enough money to fight Ford....
97stoker350
south central pa
I've found that if your work in on the motor or trans you should plan to have enough money to do the work two or three times. Very nice truck op get a level and some forces on that bish
Jassman
MS
New shock on!
I put those same shocks on the rear..adjustable and went with the 2.5's on the front and stabilizers as well. Best shocks I have ever bought. BTW..I like that Caribou and the 8' bed is all I ever get as well..
MrGTO
East TN
Im not changing ride height. I pull a 5er and it sets level to a little tail high with it hooked up. I hate a saggy rear end!
MrGTO
East TN
Josh from Diesel Cartel hooked me up with a set plus stabilizer. The fronts just got here yesterday got to put them on today and ill be set. I couldnt beleive the difference just rears made i cant wait to have all 4 on.
The day i bought the truck on the way home i hit a couple pot holes on the interstate and had a little bit of the death wobble i said *** this im getting new shocks and a stabilizer. I then saw on the forum how ****ty the shocks were. Mine sucked from day one, lol.
8ft bed is a must for a work truck.
