Will@Rudy'sDiesel
15' Race tuning is in Beta. We loaded it on the truck yesterday and I was very pleased. We received some updated files today and it made a new truck all over again. Truck holds 41psi of boost and drives very smoothly.
Do you forsee any issues with the stock turbo and that much boost or is the final tunes Thats will be released closer to stock boost levels?I thought I read Somthing about the earlier 6.7's having turbo issues running more boost and I wasn't sure if that would be an issue with the new 15' turbo.Thanks guys!
Charles
different turbo altogether on the 2015
I REALLY need a test tuner for my truck! I can't wait any longer!! Drove over 12 hours today some loaded and some unloaded all interstate.. I can't take any more regens!
a buddy tested his on the dyno today, it did 528 , said the injection pump was stronger than the 11-14 , backpressure at 30psi was almost 60 , due to the small turbine. that's the bummer part.
I read somewhere they ran 36lbs on a 15 Turbo. I wonder what the BP would be there.
They got 41psi fyi
Wastegate kits are in the works guys!
