2015 turbo water inlet differences?
ford rules
Hey guys!!
So im doing a 15 turbo swap on my 2012 and I went to install the water line and the hold down tab on the water outlet is about 180* off from where it should be.
Ive found a few people saying there are 2 water lines anyone know if there is truth to this or did I somehow end up with a misfit turbo.
Water line P/N is fc3z-9u469-a
Turbo is fc3z-6k682-b
Thanks for the help!!
PasoF450
There is one water line and one oil line. You will need the 2015 water line.
FC3Z-9U469-A
WATER OUTLET
So it sounds like you have the right part.
ford rules
There are 2 different water lines, they updated them at some point or another one has the hold down bolt on the left and one on the right. Parts numbers are the same besides for the last letter. One ends with an A and one with a B.
