20x12 AF 35x12.5 toyo mt
Logant_14
I wouldn't say that. The tires originally came off a 6.0 and had no contact anywhere and wasn't trimmed. It didn't contact on mine unless the suspension flexed while the tires were turned so I went ahead and trimmed the bumper.
Koda22
Ruidoso, NM
That looks great, but I'm worried I wouldn't have the same stance with my truck(04) any input on this
Blacksmokin22
depends on the offset of the wheel. we've put many of sets on customers vehicles with no rubbing/ nor trimming. this is 05- present 4wds also
crash86
TX
So 20x12s with a -44 offset will not rub? I'm confused why some are saying it will and some say it won't. Mines an 06 4wd
Blacksmokin22
-44 offset will rub with stock height w/ leveling kit. if you don't want rubbing with no trimming, stay down around -16 to a positive offset to work. does this clarify for you?
04cr450
harford county, maryland
Id like to this as well.. im about to order up some moto metal 962 20x12's -44 offset and 305/50's. Truck is an f350 with 250 blocks in the rear and new "x" code springs in front. Will this setup work? Ive heard mixed answers yes and no.
DEEZUZ
NO PUKESTERS
NWI
Back to these tires, are they good in the snow? I was always under the impression that mud tires were junk in the snow
97stoker350
south central pa
Honestly my ss iroks are hands down the best tire in any terrain that I have used. They are unbelievable in the snow even with a lot of air pressure. Keep them clean in mud and u will go through wherever you're at. Only downsides are they noisy and don't wear well but traction is great in all conditions
nickt82
So I have a 06 f-250 with a 4.5 rough country lift will 20by12 with a -40 fit with a 35 inch tire
